Brief Description: Organizing Center Section Components
In this work session I organzied the parts for the fuselage center section. While reviewing the parts and DWG's I discoered that I had created an additional countersink on the F-605C Bar doublers. Apparently onstead of countersinking the doubler, you will actually trim the adjacent F-634 Seat belt anchor. So I cleaned out the primer with MEK and filled the two incorrect countersinks with JB Weld in preparation for the rivet to pass through F-605C Bar doublers. See Below.
