Brief Description: F-706 and Bellcrank Support Ribs
In this work session, I fluted the halves of the F-706 Ring Bulkead and fitted the sides and the bottom section together and clecoed the entire assembly together. I then cut the F-728B, -729B, -729C out of the AA6 063 x 3/4 x 3/4. I then fitted the F-728B and -729B to the F-729A and -728A . However I had some querstions about positioning and the edge distance on the F-728B and -728B, so I did not match drill the parts together.
