Brief Description: Match Drilling and Countersinking the F-704G
In this work session I match drilled the F-704G Center Section Vertical Bars to the F-704B Center Section Aft Bulkhead. I aligned the F-704G Center Section Vertical Bar using AN4 bolts. Then I marked and countersunk the forward sides of the F-704G Center Section Vertical Bars.
