Brief Description: Installed the Leading Edge Inspection Panel
I completed the leading edge inspection plate mounting. After scuffing and priming the surfaces, I then dimpled the mounting plate and riveted on the nutplates, and then mounted the backing plate on the left wing leading edge with rivets and the rivet squeezer.
