I gave the primer a few days to dry, then I used the pneumatic and the manual squeezer to join the rear spar and the reinforcement plates together on the left and right spar. I then mated and match drilled the left wing together. Adfter I accompolished that I disassembled the left wing, assembled the right wing and match drilled all of the spars and ribs together.
