Brief Description: Deburr & Cleanup of Aft Fuselage Side Assemblies
Deburred part of the right side assembly. I spent a lot of time on the lower longeron; the longerons have a lot os small lines and nicks on them from the factory, so I wanted to make sure they got smoothed out. There are especially some casting peel in the bend corner, so I used a 150 grit sanding sponge to get in the corner and smooth it out.
