Finally after several fills and sanding’s the underside of the right wing is finished and the trailing edge of flap and aileron brought in line with the wing tip, which was a challenge because of the moulding of the wing tip. To accomplish a straight line I had to build up the trailing edge on some places just by a 1 or 2 mm. At the end it worked out very satisfactory.
