Brief Description: Finising the Top Side of the Wing
Finally I removed the right wing and turned it over to finish the top side. There is only the wingtip joint to glass and the fuse fairing to fill and sand. As long the fuse was turned I used the opportunity to fill in the inside of the luggage area, was pretty rough glassed!
