Over the last three days I spend time with filling and sanding; filling and sanding and again. Will get it soon right. Also started marking the mounting holes on the firewall; only to find the pre-cut firewall was little bit on the smaller side, some edges vary from 3mm to 10mm cowl clearance. Where 10mm is and looks a bit much? Before I proceed I need clarification to get not in trouble for inspection!
