Preparing the wing tip for final install, I glued the cover piece into the trailing edge which is a 10mm balsa sheet enforced with a 1mm glass sheet. All glued square into place. After drying further prep work drilling all the installation holes for the wing tip joint, which I use again the alu stripe to distribute the load when gluing the both part together, worked fine for the left wing!
