Lined up the top surface of the flap and aileron, clamped and drilled the bracket to the Flap alu support. So far everything looks ok and is working out.
As next I worked out how to install the wing tip, first cut the fibre glass away and positioned the nav light onto a flat surface. Prepared the mounting and the connection for the light.
