Soldered the socket lead to the servo and mounted it onto the tray, which get fit into the elevator. I used a special Turck Cable with an M8 screw socket 6 Pin connection. These cables get made on order therefore I had to wait for two month to get them but it was worth. The servo tray will be hold in place by front screws into the elevator and a latch on the back inside.
