Brief Description: Filling the HS Fairing Underside
Multiple steps filling and sanding ended in a satisfactory result. At the same time I started to prepare the underside of the fuselage for painting / joint repair. I filled all air bubbles with Epoxy Glue and will also apply a thin layer of glass to avoid hair cracks along the joint line of the fuse after painting.
