Installed and riveted the hinges to the left side of Elevator. I measured first the total span of the HS and then calculated the minimum gap for the bell-crank to work out the correct position for the elevator hinges. As I before straightened the elevator leading edge, I used the ruler to get the hinges in one line. So far all worked out very well.
