Before drilling the AOI holes I like to confirm that the angle is correct for both sites! I build therefore this simple incidence meter and used my level to check. First I lined the left stab up to match the root, and then I winched the tail up so that the incidence meter is level. After this I had only to check the right site to match. A little correction was required
