After removing the gelco on the side rails I fitted the seat onto and floxed them into the fuse. This way I was sure they are at the right place, angle and height. Both side rails ended up flat to the side of the fuse, only the curvature of the fuse on the left was not quite matching the rail. Needed a bit more flox and all was good. Some more sanding on the wing tip and filling some more pin holes will soon finalise this part.
