First trail fitted the seat and middle console, some sanding was required to make a good fit. Unfortunately the right seat is not fitting nicely to the wall, have to think what to do with that. I checked the manual and the same problem was visible in the manual's pictures as well! One was certain that all had to be removable as in my version the landing gear supports braces to the middle and may need changed after a heavy landing! To secure and install the seat supports I installed nutplates for the seat mounting, five screws on either side should be enough to hold the seat.
