Brief Description: Fitting the Centre Console Mounts
I fabricated some mounting brackets to mount the centre Console into the fuselage. I used nutplates on the alu angles to screw the console on and drilled few holes for enforcement and better grip of the epoxy. First I floxed them into position with the seat installed so that all was at the right position. After the epoxy cured I sanded excess epoxy first off and shaped everything to put two layers of glass onto, for enforcement and better bond. And again sanding on the wing tip
