Garys RV-7 Builders Log
Date:  7-6-2007
Number of Hours:  1.50
Manual Reference:  6-2
Brief Description:  Started on the empennage front spar.
This morning I started working on the front spar for the empennage. I first clecoed the spar channels (HS-702) and reinforcement angles (HS-710 & HS-714) together and match drilled the proper holes saving some for later as noted in the manual.
Next I took everything apart and tapered the ends of the reinforcement angles to the proper dimensions on the bench grinder using the scotchbrite wheel. This took some time and I went slow to not heat up the angles beyond what I could hold on to. They turned out nice and look pretty sharp for doing it by hand.
My neighbor Don and his wife Janet stopped by for a few minutes tonight to visit. Don is a true aviation expert having flown B-47's in the Air Force and retiring from a major airline as captain a few years ago. He has worked on quite a few restoration projects and currently owns several airplanes and will be a great resource to look over my work and make suggestions for improvement. I hope he stops by often.
Don noticed the length of the rear spar rivets as being shorter than standard and I told him about Van's saying they were OK for this application. He was still a little suspect and I will do more investigation just to double check, but I have read several places where they will be fine. This is an important component, as most are on an airplane and I will make sure it is right. He did find one other rivet that was not squeezed properly and that will be replaced. Thanks for the input, Don.
Front spar channels and reinforcement angles.
Reinforcement angles after tapering ends.
Don checking on my progress.
