Brief Description: multiple miscellaneous small tasks
spent today on a random collection of miscellaneous tasks. Installed the compression springs linking the tailwheel to the rudder horn. Installed drilled bolts, castle nuts and cotter pins on the hinge bolts holding the rudder to the vertical fin spar. Continued to rearrange the hangar for ease of access to the thatcher, this may be a never ending process. I started to work on hooking up the ailerons, and realized that my belcranks are according to the original design. This was disappointing, because I had believed that my belcranks were updated, for some reason, but that did not turn out to be true. I built my wings years ago and they have been sitting in storage. When I compared my belcranks to the original plans, they matched exactly, so obviously I did not have the updated design when I made them. So this is going to be another case of backing up to make corrections before I can move forward,
