Finally got the right-hand wing tip completed, including wiring in the flashing LED light. Also continued work on designing and accumulating parts for the fuel system. Since the pre-installed outlet on my fuel cell is AN-8, I decided to keep the hose, valve and filter at AN-8 as well, until I am forced to adapt it down to AN-6 at the Gascolator. I am hoping that this will give it enough head pressure to gravity feed the gas to the engine, and eliminate the need for fuel pumps.
