N983LK
Date:  2-26-2023
Number of Hours:  0.00
Brief Description:  Modified forward baggage floor
My brake reservoirs are mounted directed to the master cylinders and I have to remove the entire forward baggage floor to check the fluid level so I decided to build another one, this one with a removeable section to facilitate checking the fluid.
The first step was to determine where the removable section should be so today I built a cardboard mockup to use in finalizing the location.
I then transferred the cutout lines to the replacement baggage floor that I had bought from Vans
Cardboard mockup
Cardboard mockup
Cut lines layed out on baggage floor
