Brief Description: Connecting Rods and Crankcase internal assembly
Bob Barker and I had a good day today. We can truly say the engine assembly is under-way. Today we completed the Connecting Rod Assembly, installed the Cylinder Head Studs, the Oil Pressure Relief Plungers, the Main Bearing Stud Seals, the Cam Bearing Dowel Pins, the Cam Bearings, and the Valve Lifters. We also test fitted Cam Shaft in each Case half. These are all the parts required within the Case.
