Brief Description: Riveting the left elevator / building trim tab
Upper and lower elevator tabs bent. Inner side primed. Riveted E-703 end rib to E-704 counterbalance rib. Riveted E-610PP, E-611PP spar reinforcing plates and K1000-6 platenuts to E-702 spar. Completed trim tab skin E-619-1-020 trailing edge bend. Edge finished trim tab skin. Inboard and outboard trim tab sides bent. Clecoed E-607PP trim tab spar to the inside bottom surface of E-619PP-020 trim tab skin. Clamped E-718 to E-717 trim tab horns and aligned with clevis pin. Clecoed E-717 outboard horn to trim tab skin. Clamped E-721 trim tab hinge to the top flange of E-607PP trim tab spar. All holes attaching E-619PP-1-020 trim tab hinge drilled to E-607PP trim tab spar and E-721 hinge. Drilled the end tab holes on both sides.
