Brief Description: Drilled top FW & glare shield to attach strap
Drilled top FW & glare shield to attach strap after bending tabs to fit. Will probably rivet the strap to the FW and install #6 nut plates for the glare shield attachment via #6 screws. Also drilled the instrument panel to the glare shield. Will install CS #6 nutplates to the instrument panel tabs so the glare shiel can be attached via #6 flush screws.
