Instrument panel layout: Dynon 10" Skyview, Dynon COM and Intercom. Panel made from .063 aluminum riveted onto the original OneX panel. All but outer 1" perimeter of the original panel will be removed. The lower edge of the new panel will be 2" below the original panel and reinforced with a horizontal 1" angle. The angle will be tied into the fuselage top stringers.The new panel will be removable via an AN3 bolt on each side and the glare shield screws.
Not sure how much control stick clearance I will have with the panel, if any. If needed I can remove the center drop down area and relocate the MP3 player, vent and controls.
