Intalled the two rudder cable fairings. Also poped in the 1" snap bushings into F22-02 L&R. I used 6" pieces of 1/2" OD Tygon tubing inside the fairings to protect the cables and the aluminum fuselage side and fairings. I slit the tube open so I could get the cable inside it and then I used an Adel clamp to achor the tubing inside the fuslage. Once that was done I installed the aluminum fairings using #6 recessed nutplates. Hopefully the pictures will show what I did, perhaps overkill but I didn't want the rudder cables chewing up the aluminum.
