Brief Description: Worked on rudder cable holes & idler assembly
Enlarged the rudder cable pass through holes to 1" diameter in the left and right F22-02 vertical channels. Moved the holes outward and down when enlarging them to more center the cables in the holes, Will also insert 1" snap bushings into the holes to protect the cables and channels.
Ran into several problems with the Machined angle option Idler assembly angles. The predrilled mounting holes do not line up with the fuselage longeron holes. They not only don't line up, I can't find a location where they will not be interferring with the existing holes in the longeron and skin. I'll probably make new angles for this assembly and match drill the one angle to the longeron and I will also add 3 additional holes centered between the existing longeron and skin holes to provide the additional support required by the idler assembly. I'm also going to use a longer bronze bushing, 1/4" instead of 3/16" for the stick to idler rod plate. Will also use an AN470-4 capture washer on this assembly similar to what you would use on a bearing hardware callout.
