Jean RV6 Construction Log
Date:  10-3-2021
Number of Hours:  10.00
Brief Description:  Many errands in preparation of riveting
This weekend I did many little things ... deburring holes, dimpling, priming parts of my dismantled top fuselage. I also installed the ADAHRS support, the ELT tray, etc... I have also drilled many nut plates as well !
One thing I wanted to do was to add a quick access to the ELT and the bellcrank behind the rear baggage wall. I made a hole 8" X 8" and hinged it at the bottom and made a stop/support and holding the door closed with 2 screws. The result is what I wanted. Quick access , big enough to peak behind !
door open with a view from the inside
back side view
back side view
Closed door.
Closed door.
