Today I finished installing the nut plates on fiberglass tip. Then proceeded to install the empennage, at least have the holes drilled so at the airport the reassembling will be much faster.
But before drilling, you check it 10 times so no mistakes can occur. Hence why it took me so long to get it going !
Last I even tried the Vertical stabilizer ! It starts to really take shape !
