Made a couple of spacers per the plans to hold the aileron hinges in place. I also had problems installing the bellcrank because the right wing uses the part number W-412-L and I thought it should have been W-412-R ( The plans say to use -L. Doh ). After Matt B. pointed that out I was off and running again. Once everything was in place I set the position of the aileron stop.
