Brief Description: Addition of Panel Gauges to Pod
Today I mounted the Panel to the Pod and the Pod to the Gyro. Mind you, the wiring isn't done yet. This was just the initial fitting to see how well everything fit together. Wiring should go fairly smoothly (I used to do that in the Air Force).
