Today was a shorter day. I ran the remaining wires from the stick that control the air trim valves and wired them to the valves. I also connected the tubing from the pump to the reservoir and cut-off switch. Now, when the trim pump is turned on, the reservoir will pump up until the cut-off switch reaches pressure, and the switch(es) on the stick will open the selected valve(s) to trim the rotor head.
