Brief Description: Assembly of Upper & Lower Engine Mount Parts
Here is where the long time took! After the assembly of the Lower Mount, the Upper Mount and Engine Mounting brackets had to be all assembled. Also, the 2 tabs that hold the muffler were attached. This required the use of mechanical fingers, and a LOT of patience! Time consuming, but the finished project looks great.
