Connecting the flap and aileron was tricky. Getting your fingers into those tiny spaces and assembling the washers and bolts without dropping the washers was a mystery until I discovered by using a dab of white grease on my finger tip I could keep the washers in place without dropping them through the slot. It worked out well and a dab of clean grease can't be bad.
