I Cut out the “D” panel and fitted it with anchor nut. Also cutting out the access holes in the bottom and made 3mm ply panels. After trimming the outside edge, I fitted it into the fuselage to get a good fit and to measure the height of the support ribs which are bonded to the underside of the baggage bay.
