Construction Of the Europa XS
Europa XS
Mods
6-5-2009
Bottom Of the Rudder
After doing the Singleton Rudder mod, I needed to repair the bottom of the rudder where I had cut it off earlier. This is simple enough. A block of foam is stuck on and re shaped to the correct shape. I covered with 3 2 ply’s of bid.
Foam Shaped
Bid Layup
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
