Construction Of the Europa XS
Date:  5-27-2009
Number of Hours:  4.24
Brief Description:  Rudder Mod
After fitting the rudder, I continued with the Graham Singleton Rudder Mod. I fitted the pre made inset into the Rudder. This is a bit tricky to get it in the correct position. (I Used a Gig) The next job it to fit the push rod which I made from the left over mass balance mod. (Old Arm) Then to get 30 degrees deflection either side I marked a line on top and measured the deflection from there. All fitted together well.
Rudder Insert
Rudder Insert
Push Rod
Push Rod
Works very Well
Works very Well
