Brief Description: Graham Singleton’s Rudder push rod mod
I decided to fit Graham Singleton’s Rudder push rod mod. This is a much tidier way and more reliable than just connecting the cables to the bottom of the rudder. Graham sent me the parts, and it is a simple assembly job. This is fitted into the bottom of the rear bulkhead. 3mm ply wood hard points have to be fitted for the fixing area. The Bell-crank and brackets are simply bolted into position 5” to the bottom bracket and bedded on a mix of flox.
