Lots of unbolting and bolting the spar intercostals to fit the seat ribs. Building a plane is lots of math and figuring out the order of tasks so you don't lock yourself out of an area you still need access to. This day was full of both!
Made the A3 brackets. These hold the front control stick assembly via FMN10 nylon bearings. No waterjet this time, I cut these manually.
