Brief Description: Mount nose wheel fork to the strut axle
The front nose wheel fork assembled with fairings bracket installed. The axle assembly was sized to the correct length to fit precisely between the the wheel bearings. The aeroplane now can be supported on it's gear. At this stage the rear still needs support as it does not have the weight of the engine on the front. The nose strut alignment is checked to have the pivot axle trail the vertical position btw 1-3 degrees. Shim spacers were again used to obtain the correct degrees.
