Brief Description: Position, drill and rivett the transfer pump mount
We installed the aluminum doubler sheet on the lower skin as reinforcement. The doubler has 16 rivet holes. Fuel pump was fitted. The fuel pump is is required to pump fuel from the outside auxiliary tanks to the main centre tanks. Each wing has 2 tanks each.
