Brief Description: Install flap deployment and retraction cable
We made up the inboard cable guides from polyethylene block. This was cut into shape and rivetted to the guides. This is to ensure the cables are gliding over a smooth surface and supported in the correct area. The diagram for the flap cables took a little while to work out but after realising the cable cross over to the other side of the fuselage; we had it under control. The cables join onto the flap handle and form the loop.
