Brief Description: Fitted, Drilled, Primed & Assembled Seat Belt Atta
Worked on laying out the dimensions on the seat belt attach angle that fits into the lower aft section of the fwd fuselage. Fitting and drilled all of the clips and angles per plans. Cleaned, deburred and primed the parts. After the primered dried I assembled and riveted the parts.
It was getting late so I just placed the assembly along with the idler bracket in the fuselage seat area for test fitting. I'll work on fitting and drilling it tomorrow.
