Brief Description: Fitted and Pilot Drilled Aft Zee Assembly
While fireworks were going off everywhere around the neighborhood I was drilling away at the Aft tunnel assembly. Nothing really important to say about this assembly other than trying to make sure it is square and straight so that the spars will be able to slide in later on.
There will be a considerable amount of countersinking and dimpling that still has to be done so that the inside of the tunnel is smooth.
