Eric Seber - Waiex Project
Date:  10-14-2012
Number of Hours:  4.00
Brief Description:  Organized Hardware Kits
Today I spent several hours organizing the remaining components of the hardware kits that arrived from Aircraft Spruce. The only part that appears to be back ordered is the 4" tail wheel. I'm a ways off from needing that part! I also purchased 3 - 8 foot 2x4s and made a frame to stiffen a 3/4" sheet of plywood to use as another work table. I quickly realized that my hightop bench was not going to be sufficient for building the wings. It's cheap and works great. I just placed the table top on the two saw horses for the perfect height. Later on I can take the top off to make room for the fuselage build later on.
Organizing Harware Kits
Framed Up a 3/4
Framed Up a 3/4" Plywood Sheet for a Table Top
