Rans S-7S Courier
S7S
LH Wing
10-10-2009
05B-02
Fuel Tank Installation
Riveted a single nut plate to the top of the S2-SAB.
Installed the outer tank support tube.
Positoned the fuel tank with 1/8 gap in front and between compression tube.
Bolted the wing tank mount brackets to the fue tank.
Two clamps added to the two rear outboard brackets. Used loctite blue to all the bolt threads.
Drilled to the brackets into the support tubes and rivited the brackets in place with stainless steel rivets.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
