Rans S-7S Courier
Date:  10-10-2009
Number of Hours:  1.00
Manual Reference:  05C-01
Brief Description:  Aileron Cable Installation
Installed the Aileron Cable and Aileron Link Cable to the Upper Arm Bell Crank as per parts manual, included the two stainless steel bushings.
Installed cotter pins and tighten all connections.
Checked entire assembly for free movement and friction.
Routed cables through ribs and through the Cable Rub Block.
Cut white plastic anti-chafe to length and added to the top of second diagonal.
