Started with the LH wing topside up, rolled out and cut the top layer of fabric.
Trimmed of the excess fabric.
Bonded the fabric along the rear side of the trailing edge spar and to the forward face of the leading edge spar.
Bonded the fabric to the root rib. I still have to glue the fabric to the tip, when this is done the wing can be turned around. With the bottom side up I then can glue the extending fabric around the leading edge, trailing edge, tip bow and the root rib.
The last thing will be to pretension the fabric before the bottom side is covered.
