Rans S-7S Courier
S7S
07A-01
Wing LH Covering preparation
Cleaned the entire frame and removed all metal shavings left from drilling.
Used Scotch brite on all sheet metal surfaces, cleaned with acetone.
Cut the formed Lexan bolt cover, glued on the bolt cover.
Applied anti chafe tape around sharp edges.
Brushed two coats of thinned polybrush to the sheet metal. The thinned polybrush prevents pin holing in the paint finish.
The lefthand wing is now ready for covering.
Bolt Cover
Anti Chafe Tape
Two coats of Polybrush
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
